Quicky: What is the pressure sender mounted on the same pipe as the oil sender?
Old Jul 5, 2002 | 02:01 PM
lock's Avatar
Car: 86 IROC-Z
Engine: Superramed 355 w/ intercooled T72
Transmission: T56 -=- www.iroc-ss.com
Im replacing my oil pressure sender and I had disconnected the other sender that is on the same pipe... now when I hook up the wires to the other sender, it is starting my fuel pump.. is that normal? I havent checked to see if it stops though.... my fuel lines are disconnected at the moment as well and it was going all over my shoulder .
Old Jul 5, 2002 | 02:11 PM
lock's Avatar
Car: 86 IROC-Z
According to this: https://www.thirdgen.org/techbb2/sho...ght=oil+sender
Its the oil pressure switch... another fine example of doing a search before posting! DOH... Im in a rush .
89GTAOz
May 16, 2020 09:31 AM
db057
Aug 22, 2015 08:17 PM
Navy8125
Aug 21, 2015 09:32 AM
355sbcTPI
Aug 19, 2015 04:38 PM
