Noise from front of engine
Old Jul 5, 2002 | 04:25 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
I noticed today a noise coming from the timing cover, it gets faster/slower with rpm. i ran the engine without the water pump belt for a few seconds to make sure it wasn't the water pump making the noise. the timing set is a double roller i put on a few months ago. i listened for the noise with a piece of tubing, the noise is the same by the cam gear and crank gear but is a lower pitch by the crank gear.
i suspect maybe the cam gear loosened up and is wobbling. i think i'm gonna pull the timing cover off tomorrow and have a look. any ideas what could be wrong?
Old Jul 6, 2002 | 09:25 AM
Vader's Avatar
It could also be a stretching timing chain, misalignment of the sprockets, or a single loosened cam sprocket bolt scraping the inside of the cover.
Old Jul 6, 2002 | 10:57 PM
350turbo411's Avatar
Car: 1983 Z28 Clone
Transmission: TH350
yep.. .i'm with the loose chain... mine has been doing that for about 4 months.. its just an extreme pain changing that thing ..with the oil pan and all.
rob
Old Jul 8, 2002 | 12:29 AM
Car: '87 Camaro LT
Engine: 355 L98
well i fixed it, two of the cam sprocket bolts loosened up. now since putting everything back together i'm getting a new noise. i only hear it when i'm at half throttle or more and only when in any gear, it won't do it in neutral or with the clutch disengaged. kinda sounds like something's loose and is rattling against metal. i hope the t5's not takin a dump on me already
Old Jul 8, 2002 | 09:22 AM
Merlin's Avatar
Service removeable LocTite (242) on the cam sprocket bolts is always a good idea to prevent that sort of problem.
Good luck on tracking down the new noise. You might try raising and blocking the car securely to test your transmission and drive line theory.
Old Jul 8, 2002 | 09:37 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
New noise description sounds like your cat, or other exhaust system part...
Old Jul 9, 2002 | 10:39 AM
Car: '87 Camaro LT
Engine: 355 L98
I don't have a cat so it's not that. I thought it could possibly be the muffler because it was making a different noise for a while a few weeks ago but then stopped. Guess I'll keep looking.
Old Jul 9, 2002 | 08:13 PM
Car: 1983 Z28 Clone
Transmission: TH350
mine is making that noise too...... sounds like its an exhaust leak muffled.. but its not..... and its only under acceleration... its worse ..with the more weight i'm carrying ...ex... full tank of gas.. and one passanger..
rob
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Sep 17, 2020 08:26 AM
B_Dubya
Aug 26, 2015 05:09 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
BlackBoulder
Aug 11, 2015 11:15 PM
