bad fuel pump
Old Jul 6, 2002 | 12:42 PM
92RSQ8's Avatar
bad fuel pump
could some one please tell me what i need to do to change a fuel pump?
my car is cranking over but is not getting any gas.
any help would be appreciated
thanx.
Old Jul 6, 2002 | 05:32 PM
Jza's Avatar
Jza
Try here. <form action="search.php" method="post"><input type="hidden" name="s" value=""><input type="hidden" name="searchdate" value="-1"><input type="hidden" name="beforeafter" value="after"><input type="hidden" name="forumchoice" value="13"><input type="hidden" name="action" value="simplesearch"><input type="hidden" class="bginput" name="query" value="change fuel pump"><!-- go button --><input type="image" border="0" src="images/top_search.gif"></form>You basically look up under the back of the car at the fuel tank, and see everything there in the way? All that's gotta come out. Good luck and don't sweat it. It's a time consuming job, but it's pretty straightforward. Give yourself at least 8 hours if you've not done one before. And hit all the bolts with penetrating oil the night before you do the job. You'll thank yourself later.
Old Jul 10, 2002 | 10:02 AM
felo72's Avatar
One thing I'd like to add, make sure you check everything else out before you start the job. Beleive me, I had the tank out and did all that work to find out the fusable link by the battery was fried. Check the link and the relay before you try to change the pump. It will save a couple of dents from a thrown wrench.
Glowsock
Jul 24, 2025 03:15 PM
mustangman65_79
Apr 14, 2017 05:37 PM
Bryan F
Aug 18, 2015 02:28 PM
Winchester1094
Aug 18, 2015 10:23 AM
Newguy91rs
Aug 7, 2015 09:51 PM
