blue smoke PCV???
Old Jul 8, 2002 | 10:34 AM
RedZ28Chik's Avatar
blue smoke PCV???
ok here is the problem, when i first start my car, when i rev the engine, or i am accelerating from a stop, bluish grey smoke comes out of my tailpipe. Its not a great deal of smoke but its enough for the DMV to fail me for smoking. I know this could be a few things and i do know oil must be burning somewhere. It doesnt happen when im driving either. i plan to run a compression test on the car later this week, but i was wondering what the chances are it could just be my PCV. I just gave the car a tuneup and my plugs were wet black on the tops. Any ideas???
Old Jul 8, 2002 | 11:02 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Probably valve guide seals if they've never been replaced. That's very common in Chevy small block motors.
Old Jul 8, 2002 | 11:15 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Originally posted by RedZ28Chik
Any ideas???
How many places did you ask this question? You didn't like my answer on the TPI Board (valve seals) so you decided to ask the question all over the place hoping someone would tell you a different answer?
Well, you can ask the question 100 times, it's still your valve seals.
Old Jul 8, 2002 | 11:25 AM
MikeS's Avatar
I've gotta agree to the seals. But hey, PCV only costs $2 so it's worth a try. A short term solution could be an anti-smoke oil additive (STP makes one that works reasonably well). They make a visible difference, but I can't say how well it would help you pass an exhaust gas analyzer test.
Old Jul 8, 2002 | 12:04 PM
RedZ28Chik's Avatar
the reason i posted it here was becuase i realized i posted my question in the wrong area, for some reason i wouldnt let me delete it out of the TPI discussion forum
Old Jul 8, 2002 | 12:05 PM
RedZ28Chik's Avatar
i did use the stop smoke additive and it made absolutely no difference
Old Jul 8, 2002 | 04:35 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
could also be your rings. I had totaly trashed vavle guide seals in my 305 and it did most of its smoking right when the engine started. Bad valve guide seals are far more common with our v8's, tough. All those oil additaves are garbage. Nothing more then modern day snake oil.
Linson
Oct 24, 2025 02:00 PM
Pac J
May 17, 2020 10:44 AM
gord327
Oct 3, 2015 01:25 PM
bschmale66853
Sep 30, 2015 08:11 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
