i want a date with more torque
Old Jul 8, 2002 | 09:51 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
give me some idears to produce the most torque. i want a torque puppy to show off in lol. i just believe in more torque over horses but more horses with more torque is just as good. lol sorry guys i am in a wierd mood but still curious. thanks dudes and dudettes!
Old Jul 8, 2002 | 11:12 PM
bob8748's Avatar
Well... do what I'm doin, Put a big "Poncho" in it,
Old Jul 9, 2002 | 11:58 AM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
Easy...more cubic inches. 383...406...or big block.
Depends on your budget, but I would stick with a 406 so you don't need to worry about swap issues.
Just my $.02.
Old Jul 9, 2002 | 12:45 PM
BAK12484's Avatar
well how much torque does your current motor have, and how much do you want (realistically) ??
with stock internals, my 350 TPI has been dyno'ed at 363 lb ft @ 2800 RPM....throws your *** in the seat pretty good i'd have to say Now i'm wondering what i could pull w/ upgraded heads and cam.
Old Jul 9, 2002 | 02:41 PM
Merlin's Avatar
Three things can get you more torque at teh flywheel:
Longer stroke (most effective mechanical advantage);
Longer rods (better mechanical efficiency);
Bigger explosions (just plain more power).
Other ways to get more torque at the WHEELS is to modify the stall characteristics of the torque converter (in an automatic), numerically increase the rear axle gear ratio, or decrease the tire diameter.
Of course, if you can make more flywheel torque AND increase the driveline torque multiplication, you'll have even more increase. Just remember that torque that exceeds traction is wasted energy. If you can spin the tires all the way down the track, you have too much torque. Beyond that, all you need to do is learn to control it.
no green
Jan 9, 2016 09:22 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
