how do u.....
Old Jul 9, 2002 | 08:56 PM
1982chevycamaroz28's Avatar
how do u.....
how do u do a vacume test? becuz i asked the mechanic at work about problems ive been havin and he said do a vacume test and see what it gives me. and i told him about the problem i had and the things ive replaced and he told me aboutthe vacume test. so if anyone can tell me how to do a vacume test thanx.
Old Jul 9, 2002 | 08:57 PM
Jza's Avatar
Jza
You take a vacuum gauge and a plastic t-fitting and plumb it into a vacuum hose and look at the gauge.
13 is usually a good reading.
Old Jul 9, 2002 | 10:11 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
13 at idle is atrocious. It should be somewhere in the neiborhood of 17-20 on a stock motor
Old Jul 10, 2002 | 11:33 AM
so i should spend the 30 or 40 bucks for the vacume tester at work and use that?
Old Jul 10, 2002 | 11:47 AM
Car: 88 Camaro SC
Engine: SFI'd 350
yeah... or you can use a vacuum pump, too. Mine has a bult in vacuum gauge so i can use it to test vacuum as well as test vacuum activated devices. I got mine from sears for around the same price.
