Smog pump question (searched boards)
Old Jul 10, 2002 | 09:32 AM
83tranzam's Avatar
Car: 1985 Trans Am
Engine: LB9 5.0 TPI
I did a search for this, but couldn't find anything to help me...
I've been reading about the smog pump removal on the 305...i'd like to do this, but I noticed some concerns were raised about removing it if you have a computer-controlled Q-jet. I have the CC Q-jet, but the belts on my '83 T/A currently are routed around the smog pump - it's just sitting there connected to the block. Do I need to be careful about affecting the Q-jet when I remove the pump & hoses? Thanks!
Old Jul 10, 2002 | 10:10 AM
Merlin's Avatar
It's no so much the pump that is a concern as the diverter valve. On some years and models, the ECM will scan for the loads connected to it on power-up. If there is no resistance detected where the port and divert solenoids are supposed to be connected, the ECM may set a code.
I'm not sure on an '83, but I don't believe you would have a problem with this phenomenon.
Old Jul 12, 2002 | 09:16 AM
83tranzam's Avatar
Car: 1985 Trans Am
Engine: LB9 5.0 TPI
Anybody else have any feedback on this?
Old Jul 12, 2002 | 09:42 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The ECM in carbed cars doesn't know whether the air mgmt valve is there or not.
You need about a 7445 or 7450 belt if you remove the AIR pump, depending on which crank pulley you have. I believe the LG4 has the larger crank pulley (as opposed to the L69's factory underdrive crank pulley) and so will take the slightly longer belt.
Old Jul 12, 2002 | 10:07 AM
83tranzam's Avatar
Car: 1985 Trans Am
Engine: LB9 5.0 TPI
Thanks for the response. Here's the deal: When I bought the car last August, it already had new belts on it that aren't connected to the smog pump. It's currently just sitting there taking up space. Can I just remove it along with the hoses, or is that going to create a problem for my carb? Thanks again.
Old Jul 12, 2002 | 10:27 AM
ace16a's Avatar
Car: 1985 Z28 Camaro
Engine: 5.0 TPI
Transmission: 700R-4
Axle/Gears: Posi Richmond 3.73
I have an 85 TPI Z28 that I removed the pump from with no problems at all, just left the two plugs hang there in case I wish to reinstall all the stuff. No error codes ever came up. Mine just had a single belt going to the crank and nothing else on it, too.
Old Jul 12, 2002 | 12:48 PM
83tranzam's Avatar
Car: 1985 Trans Am
Engine: LB9 5.0 TPI
Hmmm....then I doubt i'd get any codes either. Anybody else had success with this?
Vintageracer
Jan 10, 2020 05:33 PM
italiano67
Dec 11, 2016 09:21 AM
Juneb1022
Firebirds Wanted
Oct 12, 2015 08:12 PM
redmaroz
Aug 16, 2015 11:40 PM
jackhammer
Aug 15, 2015 10:04 PM
