Injector size?
Old Jul 11, 2002 | 03:03 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Injector size?
I'm building a TPI 383.
Intake sys will be stock except for some porting.
Heads will be Sportsman II or possibly Trick Flows/AFRs (if I can find a good deal on a set).
Undecided on exhaust, but will definately be free flowing.
Undecided on cam also, but will aim for a relatively low RPM/high torque type. Will need to get thru smog check.
PROM will be custom.
Don't want to crank-up fuel press much if any.
Roughly, what size fuel injectors should I be looking for?
Stock is 19/lbs right?
Thx..
Old Jul 11, 2002 | 03:14 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
24# should do the trick
92projectcamaro
Jan 18, 2016 08:00 AM
toronto formula
Nov 10, 2015 06:17 AM
Brother Al
Oct 14, 2015 06:39 AM
BAMiller
Sep 14, 2015 06:38 PM
