brkes bleeding off
Old Jul 11, 2002 | 05:17 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
brkes bleeding off
Ok, I know when running a performance cam, you may have vacuum issues....hasnt become a problem but something I notice why sitting at lights at idle, is my pedal will slowly loose pressure. They still work well, I just loose some pedal. As soon as I increase the rpm's the pedal becomes solid again....I dont have the specs on my cam, But i can tell ya it is very lumpy. It wants to Idle around 1000rpm in neutral and in gear lopes hard at 700rpm.
I was thinking master cylinder, but the condition has not changed since my swap....my brake fluid level stays full, Ive never had to fill it. Any Ideas.
Also my cheap uncoated headers are very close to my brake lines..(due to v-8 swap) could this cause the problem?
Old Jul 11, 2002 | 07:45 AM
Vader's Avatar
You may want to inspect the vacuum check valve on the brake booster. Replacements are only a few bucks, and a leaking valve can cause loss of assist as you describe.
Old Jul 11, 2002 | 04:42 PM
Engine: 406
thanks Vader, I'll do just that...
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
84redta
Sep 19, 2015 09:58 AM
dimented24x7
Sep 6, 2015 03:51 PM
backtothe80s
Sep 5, 2015 12:39 AM
