350 to 383 stroker, Do I need new starter??
Will my factory starter work with the 400 crank and flywheel or do I need a new one? which should I get? Part numbers are great. Engine in sig.
so long as you are using your current 350 block you can use the same starter.....(if you are starting fresh make sure the block you are getting has the same starter bolt patern. they come in straight and stagarred) some newer blocks have provisions for both.
mhatfield 14
Oct 24, 2015 07:48 AM
Mickeyruder
Sep 2, 2015 02:45 PM
Eric-86sc
Aug 24, 2015 09:01 PM
