what size cam
Old Jul 11, 2002 | 06:40 PM
d4nk's Avatar
Car: 86 T/A
Engine: 383
Axle/Gears: 3.27 9 bolt
what size cam
What would be the biggest cam i could run on the stock valve springs n rocker arms on an 86 t/a with the infamous peanut cam.
Old Jul 11, 2002 | 07:35 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
In the range of .450 lift.
Old Jul 11, 2002 | 11:03 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
You're limited to mild to moderate hyd flat tappet cams. Any thing that has to
be reved much past 5500 rpm will need a spring change.
That would be anything with 230@.050 duration or more than
.485" lift. That actually leaves you a lot of choices though.
No performance hyd rollers. They need more seat pressure than stock.
toronto formula
Nov 10, 2015 06:17 AM
gta90
Sep 15, 2015 04:00 PM
bamaboy0323
Sep 3, 2015 06:07 AM
gixxer92
Sep 1, 2015 04:32 PM
knight72
Aug 10, 2015 09:32 PM
