ZZ4 Cam + Stealth Ram
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
How well would the ZZ4 Cam complimetn a Stealth Ram? Im mostlikley picking up a ZZ4 crate motor for my GTA, and beings that the HSR will bolt right up to it due to the pre-86 heads, I think itll be a nice little package for the time beings. HOWEVER, if this ZZ4 cam wont really compliment the HSR, then Id like to know before I get it into the car. What would you recommedn?
Thanks!
-Rob
Thanks!
-Rob
Car: 4
Engine: 6
Transmission: 5
I would think it would be a good match, as long as you either use the aftermarket computer or get good at PROM burning... but of course I've never tried it
Car: 89 formula
Engine: 383
The GM hotcam would be better matched to the stealth ram.The ZZ4 cam would be better for the long tube TPI.Im going to go with the hotcam soon with my new engine.Right now I have a comp cam(L.480-.480/D210-220/LSA112) that is close to the ZZ4 and with the stealth ram it pulls to 5500rpm pretty good.With the hot cam it should pull to 6000rpm or more hard.
Stangski09
Nov 14, 2015 01:27 PM
