View Poll Results: Valve Lash on Hydraulic Flat Tappet w/ Rollers?
Less than 1/4 Turn
5.56%
1/4 Turn
27.78%
1/2 Turn
55.56%
3/4 Turn
11.11%
1 Turn
0%
More than 1 Turn
0%
Voters: 18. You may not vote on this poll
How About a poll: Valve Lash ?
Old Jul 11, 2002 | 11:50 PM
ronterry's Avatar
Car: '94 Corvette
How many turn do you use? Let us know, either professional, books, or hear say - how many turns when slack is taken up.
Not even sure if there is a different technique with rollers & flats, but for the most part let us say flats. Solid lifters - no thanks, cause I know there's a different tech involved.
To be honest, I am not even sure, there is a different tech with rollers or stamped.
How about Hydraulic flat tappet, with roller rockers – how many turns?
Ron
Old Jul 12, 2002 | 01:09 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
All hydraulic cams run at no lash (0 lash). Wether flat tappet or roller. I think you are talking about lifter preload.
The proper design preload is to have the plunger depressed .030"/.060" in the lifter, with the valve closed. Whatever amount of rocker nut turns past 0 lash that causes this is ok.
Some racing applications call for .001 to .003" lash for a racing hyd cam valvetrain to avoid lifter pump up caused by valvetrain separation at high rpm. This special setting requires frequent adjustment and is not practical for normal street use.
Old Jul 12, 2002 | 06:22 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
For high-perf street use, I set new valve trains to 1/2 turn and used ones to 1/4.
Old Jul 12, 2002 | 11:03 AM
TheLG4Whore's Avatar
Car: '86 Trans Am
Transmission: TH700R-4
Axle/Gears: 10 bolt 3.73
just go until clicking stops and then 1/4 turn or so.
Old Jul 12, 2002 | 11:51 AM
ede's Avatar
ede
i use two 1/4 turns with a ratchet, guess if i did the math that'd be about a half turn
Old Jul 12, 2002 | 12:06 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
I have always used 1/2 turn past zero lash with great results. However, with the new modifications and the conversion to CC 'R' series roller lifters I will be using minimal lash ... about 1/16-1/8 turn past zero lash.
Tim
SPEEDY Z28
Brakes
16
Apr 18, 2016 02:46 PM
sleprock
Sep 24, 2015 04:33 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
dimented24x7
Sep 6, 2015 03:51 PM
