HEI ignition problems
Old Jul 13, 2002 | 12:07 AM
87transam5.7tpi's Avatar
I got my car hooked up toa tune-up machine the other day. and found out that my igintion system was being worked hard. so......... I just replaced the coil,wires, cap and rotor today. and I hooked the car back up and it still is being worked hard. could it be the module? what exactly does that do? thanks
Also by working hard i mean taking more voltage that it should to fire. and I'm not running lean eithere cause I know that could do it.
Old Jul 13, 2002 | 01:00 AM
1a12's Avatar
sounds like the control module to me. Also i would check the spark plugs, to make sure the gap is right. That won't make a big problem, but it would also make the module work harder.
Old Jul 13, 2002 | 10:21 AM
the gap is at .040 stock is supposed to be .035 so I don't think it should be that hard on it.
Old Jul 14, 2002 | 01:50 PM
I also forgot to say that the car has been dying on me every once and awhile. especially after idleing for awhile.
Infested
May 22, 2018 11:56 PM
Bryan F
Aug 27, 2015 07:28 AM
theurge
Aug 21, 2015 12:46 PM
Bryan F
Aug 18, 2015 02:28 PM
midias
Aug 15, 2015 05:07 PM
