Can I drive without my smog pump?
Old Jul 14, 2002 | 06:06 PM
5SIZ's Avatar
Car: 1987 IROC-Z
I have the V belt system in my 87, and I just removed my A/C yesterday so I am running on 3 belts now, I am wondering what would happen if I removed my smog pump belt??? Can I run without it, I know all it does it send air through your exaust, but what will happen if I don't have it connected, I just want to run off 2 belts My friend said I would be fine runnign wihtout it, just have to put the belt back on when I go to emissions.
can someone answer my question?
Old Jul 14, 2002 | 06:25 PM
Iroc87's Avatar
Well my belt came off( how I have no clue) drove around with it like that for 2 years. Moved to Texas, failed the E check, put the belt back on, and passed with flying colors So to answer your question: not a damn thing BTW mines also an 87 TPI
Old Jul 15, 2002 | 10:11 AM
83tranzam's Avatar
Car: 1985 Trans Am
Engine: LB9 5.0 TPI
My smog pump currently has no belt running to it as well. I posted a topic last week about smog pump removal, and the consensus seemed to be that if you get the right belts, the pump can be removed all together.
Old Jul 15, 2002 | 10:19 AM
5SIZ's Avatar
Car: 1987 IROC-Z
Well, I do not want to remove the smog pump, just the belt, where I'm from you have to run through emissions every year.
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
italiano67
Dec 11, 2016 09:21 AM
mcquigg
Aug 13, 2015 02:26 PM
92camaroJoe
Aug 13, 2015 06:07 AM
