Roller lifters
Old Jul 16, 2002 | 05:04 PM
cdogc350's Avatar
Roller lifters
I know if you change lifters on an already broken in cam, it will do damage to the cam. But since roller lifters theoretically dont need to be broken in, would it be possibly to just swap them in place of non-rollers and not cause damage?
Old Jul 16, 2002 | 06:44 PM
Lounge Lizard 6's Avatar
Unfortunately, you can't use roller lifters on a non-roller cam.
Old Jul 16, 2002 | 06:55 PM
cdogc350's Avatar
thats right....the lobes are different arent they, the non roller would get caught up
Old Jul 16, 2002 | 09:13 PM
Guest
Guest
Posts: n/a
Who told you that you cant put new lifters on an old cam? At least thats how I am reading your post... No problem with putting brand spankin new lifters on a used cam.
Old Jul 16, 2002 | 11:34 PM
iroc22's Avatar
Yeah its the other way around. The lifters usually wear to match the camshaft, so you can't change the camshaft and use the existing lifters. You can change the lifters though and use the existing camshaft.
Old Jul 16, 2002 | 11:56 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
On a roller, you can change the cam, and reuse the lifters. Roller lifters can always be reused. Nothing from roller is interchangable to flat tappet/solid though.
Old Jul 17, 2002 | 02:06 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
You CAN, however, reuse your old lifters with the same cam in another engine. You just have to be careful to keep the lifters and lobes marked for each other when you reassemble it. They must match each other or all is lost
KO1
16
Oct 15, 2015 05:00 PM
skinny z
Oct 5, 2015 06:23 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
