new msd 6A, car dies while checking timing
Old Jul 17, 2002 | 01:19 AM
ChevyGuy87's Avatar
Car: 2004 Wrangler Rubicon
Engine: 4.0
Transmission: NV3550
Axle/Gears: Dana 44s with 4.10 and air lockers
i got a new MSD 6A a couple of days ago for my trans am, but the engine isn't done yet so i put it it the 6 banger camaro for now just for $hits and giggles. it runs great now, except that today i tried to check the timing. i disconnected the EST, tried to start it,but it ran for a split second then died. it did this a couple of times, then i put my foot on the gas a little while cranking. it shoots right up to 3000 rpm, revs fine, but the second it comes down to 1000 rpm it dies. it doesn't sputter, hesitate, choke, misfire, it just shuts off like i turned off the key. anyone have any ideas?
Old Jul 17, 2002 | 06:40 AM
ede's Avatar
ede
did you read the instructions that came with it? all the msd ignition boxes i ever saw you had to cut a wire to make it work for a v6, and after you cut it you can't put it back together. might want to look over the instructions again and see if you missed something.
Old Jul 17, 2002 | 09:54 AM
ChevyGuy87's Avatar
Engine: 4.0
i read the instructions, and they said the 6A works on a v6 right outta the box. it's on the box with a rev limiter that you have to cut a wire so you can use the rev limiter. the thing that i dont understand about this problem is that the car runs perfect. starts right up, idles good when the est is connected, but it dies the second it hits 1000 rpm with the est disconnected.help!
Old Jul 17, 2002 | 10:17 AM
ede's Avatar
ede
guess i've never fooled with one without the rev limiter. can you unhook the msd and time it?
Old Jul 17, 2002 | 05:55 PM
ChevyGuy87's Avatar
Engine: 4.0
don't you hate it when you overlook the small, tiny, simple answers to car problems?
Fanatic1074
Oct 3, 2022 05:57 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
RedLeader289
May 28, 2019 01:47 PM
meeklay812
Oct 1, 2015 03:46 PM
RedLeader289
Sep 23, 2015 06:50 AM
