What's the correct way to take off the serpentine belt?
Old Jul 15, 2002 | 07:57 AM
Tas's Avatar
Tas
? pics would help
Old Jul 15, 2002 | 08:19 AM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
LOL, I hope you're joking...
If not, try a 1/2" drive wrench in the square hole on the tensioner...
Old Jul 15, 2002 | 10:41 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
for some one who has almost 5000 posts i hope your joking
Old Jul 15, 2002 | 10:55 AM
kevinc's Avatar
Car: 1982 Z28
I use my 1/2" drive breaker bar in the square hole in the tensioner assembly as indicated above.
Old Jul 15, 2002 | 10:57 AM
99Hawk120's Avatar
Actually, now that I think about it, an alternative method would simply be to leave the car in neutral and put a brick on the accelerator. Once the engine reaches high enough RPM, it should toss the belt. I wouldn't suggest standing anywhere near the engine compartment though, because you might get hit by it (or by flying internal engine parts).
Old Jul 15, 2002 | 01:04 PM
Tas's Avatar
Tas
I've done it before but I'm sure i didn't do it the "right" way.
Old Jul 15, 2002 | 01:45 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
If you can't figure out how to change a serpentine belt, i don't think you should give ANYONE, ANYWHERE, ANY KIND of car maintenance or modification related advice.
Couple this with the fact that you were one of the people advocating the 'cut the trunk floor' method of fuel pump removal and all doubt should be removed about your qualifications to 'help' people work on their cars.
Pathetic. Absolutely pathetic.
Old Jul 15, 2002 | 02:15 PM
JC93Z's Avatar
Uh oh!!!!!!!!
Old Jul 15, 2002 | 03:38 PM
Tas's Avatar
Tas
I DEFY you to find that I said to cut the trunk floor.
Old Jul 15, 2002 | 08:33 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
not to take sides on this but i do beleive i saw you saying soemthing like that in a post, tas.
Old Jul 15, 2002 | 09:54 PM
Tas's Avatar
Tas
go search on my name for "fuel pump". There's only about 10 entrys because I have no place to say much of anything on them out of 4454 posts!
Old Jul 15, 2002 | 10:04 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
he never even posted in that thread
https://www.thirdgen.org/techbb2/sho...hreadid=116326
Old Jul 15, 2002 | 10:14 PM
Tas's Avatar
Tas
bah. I'd rather have ***** to ask a question than to use another "handle" to ask things like people have been doing for years now. I've pryed the tensioner with a crowbar a couple times. Ooo I didn't know to use a 1/2" drive, big deal. I don't claim to know all. I'm ignorant on a lot of things. If I need to know, I ask. If I'm wrong on something, tell me.
Old Jul 15, 2002 | 10:18 PM
Car: 88 Camaro SC
Engine: SFI'd 350
I think is was in another thread but i dont care about it that much nor do i want to be an *** so ill take your word for it.
Old Jul 15, 2002 | 11:52 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Ahh, come lay off ol' Tas. I have a buddy that knows how to pull his engine, remove the intake, heads and cam, and then reconnect it all. Yet, he didn't know how to adjust the TV cable or pull the SES codes with a paper clip.
Bottom line, we all have our strengths and weaknesses. We are here to LEARN and share our knowledge. I am positive EVERYONE has picked up a little "tid bit" from this board that was probably obvious to EVERYONE yet they never even knew it themselves.
How many people know how to "pick the lock" on the wire leads to the ECM connector? It's really simple if you play with it, yet MOST guys just "cut and splice" and never figure out that it takes only a couple of seconds to "pick the lock" of the wire lead and then you just re-pin it to the proper connector when you do a 165 to 7730 ECM swap. To do all the wires takes less than 15 minutes. Hell, you can't "cut and splice" in that amount of time.
Old Jul 16, 2002 | 06:53 AM
Helmsdini's Avatar
If you are really THAT car illiterate (wich is sad since you are a moderator on this site) and you are replacing the belt anyway why not just cut it off? then all you will have to post is the thread asking how to put the new one back on.....
... could also try reading the owners manual or perhaps go into autozone and check out that section in a hanes manual? i dunno im just throwing out ideas here...
Old Jul 16, 2002 | 07:21 AM
TPI Guy's Avatar
Car: 1968 Camaro
Engine: 406
Transmission: Tremec TKO
But seriously, you have nearly 5,000 posts. What do you post about? Do you read the posts you reply to?
Old Jul 16, 2002 | 07:28 AM
ede's Avatar
ede
what's wrong with posting just to raise your post count numbers a little
Old Jul 16, 2002 | 07:46 AM
kevinc's Avatar
Car: 1982 Z28
He moderates TBI, not a lot of skill needed when all you do is not adjust anything and not go fast.
:nono:
Old Jul 16, 2002 | 08:22 AM
Car: 88 Camaro SC
Engine: SFI'd 350
:nono:
lol... those where the two main reasons i kept my tbi. Dont have to worry about getting more tickets or doing tons of work to get it to run...
Old Jul 16, 2002 | 09:38 AM
Car: Death Mobile
Engine: 666 c.i.
The role of a Moderator is NOT to answer questions. It's to ensure that every post complies with the rules of "good conduct" that everyone agrees to when they first join Thirdgen.org.
As mentioned by someone else, at least Tas isn't afraid to ask a question in his own name. What is really sad, are the moderators that THINK they know what they are talking about and haven't got a clue what's going on. But, as I said before - a moderator's duty is NOT to answer questions, it's to maintain orderly control.
And just because you ARE the smartest person about cars doesn't meen you would make a good moderator either.
Old Jul 16, 2002 | 12:09 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
A sharp pocket knife should remove that belt pretty quickly. But I do use the breaker bar method to install the belt.
Old Jul 16, 2002 | 01:14 PM
Car: 88 Camaro SC
Engine: SFI'd 350
or the method of jsut using the two hands that *** gave you... This is the method that i used to take the serp. belt off my old-fart-mobile cutless cierra. But i was alot stronger (and stupider) tehn so i could use my bare hands to do it.
Old Jul 16, 2002 | 09:38 PM
83CAMAROMAN's Avatar
Car: 1983 Camaro Sport Coupe
Engine: 1986 305 C.I.D. Bored .030 over
Transmission: TH350 W/Shift Kit
Axle/Gears: 3:08
wow.....what happened to all the nice help that everyone gets on here no matter what the question.....i remember reading posts where some mechanics have brain farts and admit to asking something that may have seemed stupid and didt get flamed that hard.....now unless i missed the post where he claimed to be a car ***......he was simply asking a question to people that he knew would know the answer and wouldnt flame him for confirming a simple thing..
i feel bad for any newbies that now feel too embarassed to ask simple stuff...........
if he didnt know how to take off a belt then oh well
but dont hang the man
damn guys....calm down
Old Jul 17, 2002 | 07:56 AM
99Hawk120's Avatar
There's a little difference between a newbie with 5 posts asking this question and a moderator with 5000 posts asking it.
Old Jul 17, 2002 | 08:38 AM
TPI Guy's Avatar
Car: 1968 Camaro
Engine: 406
This Thread Makes Me Sad
Someone should close it for lack of technical content. I mean seriously, a serp belt, how much tech content can their be?!
Old Jul 17, 2002 | 09:04 AM
91banditt2's Avatar
Engine: 5.7 HSR
why would the word or name *** be censored?i mean goddamnit why the **** would it be?
Old Jul 17, 2002 | 09:05 AM
91banditt2's Avatar
Engine: 5.7 HSR
and why wasn't goddamnit censored?
Old Jul 17, 2002 | 09:22 AM
Axle/Gears: 3:08
ok so then what is the official number of posts allowed before you arent allowed to ask simple questions.......i just want to know so i can keep an eye on my posts........
or is it just being a moderator that makes it like that
even though it was stated that a moderaters job is not to know everything but to simply regulate the boards
i give him props for admitting that he didnt know something like that
to the rest of you that flamed him..........shame shame
Old Jul 17, 2002 | 11:44 AM
Car: 88 Camaro SC
Engine: SFI'd 350
i think it was the whole him being a moderator thing that set people off. I guess everyone has the preconception that all moderators are supposed to be certified gm techs or something and not like the rest of us and dammit, why is this still open? It just keeps coming back to the top.
Old Jul 17, 2002 | 11:45 AM
99Hawk120's Avatar
Because, goddammit, if you can't figure out how to take the serpentine belt off, then you need to pick another hobby. It really is that easy.
Old Jul 17, 2002 | 01:39 PM
Tas's Avatar
Tas
Good reading comprehension skills jerkass. I took the belt of not even 2 weeks ago to put headers on. Like I said above, I used a prybar and not the 1/2" drive like someone said was the "right" way to do it.
Old Jul 17, 2002 | 01:40 PM
99Hawk120's Avatar
Oh, I read what you posted just fine.
Old Jul 17, 2002 | 06:06 PM
ede's Avatar
ede
i think we've all had too much fun with this on haven't we?
Galaxie500XL
Feb 1, 2020 04:53 AM
iroczguy86
Sep 13, 2015 02:22 PM
MORREALE5
Sep 10, 2015 08:58 AM
MSgt Luttrell
Sep 5, 2015 11:28 AM
buckshot63
Interior Parts Wanted
Sep 3, 2015 08:10 AM
