power steering? maybe?
Old Jul 20, 2002 | 10:17 PM
black83z's Avatar
i've been hearing a whine coming from under my hood when i turn sharply at speed (25-35). Sometimes it lasts, but when i turn my steering wheel it gets slightly louder. I read in the tech section about the whine possibly being caused by a low power steering fluid problem. How do i check the fluid level? What kind of fluid should be put in it? Is that even the problem? thank you
matt
Old Jul 20, 2002 | 10:26 PM
83CAMAROMAN's Avatar
Car: 1983 Camaro Sport Coupe
Engine: 1986 305 C.I.D. Bored .030 over
Transmission: TH350 W/Shift Kit
Axle/Gears: 3:08
it def sounds like that could be the problem.....or at least its the easiest to check......just take the cap off the resevoir and the dipstick is attatched......check the level and add if needed.....go to any local parts store and get some power steering fluid......
like i said thats the easiest to check
Squeaky8791
Feb 5, 2020 08:29 PM
Vintageracer
Jan 10, 2020 05:33 PM
Chuck84TA
Jul 15, 2016 09:05 PM
evilstuie
Apr 14, 2016 08:52 PM
deracer
Apr 11, 2016 12:04 AM
