Failed Emissions
Old Jul 21, 2002 | 07:23 AM
88-droptop's Avatar
Failed Emissions
I just failed emissions for hydrocarbons(everything else was o.k) I have a Hypertech chip,160 degree stat,12 degrees of base timing).The car sits most of the time. Do any of these have anything to do with hydrocarbon failure. HELP!!
Old Jul 21, 2002 | 07:25 AM
88-droptop's Avatar
By the way I have a 88 iroc with a 5.0 TPI. Just tuned up.
Old Jul 21, 2002 | 08:45 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
HC = unburned fuel or oil
An ignition miss will cause it. If HC is high but CO is OK, chances are the fuel mixture is OK.
Define "tuned up"... you probably have at least one cylinder that isn't running at least part of the time.
Old Jul 21, 2002 | 08:48 AM
88-droptop's Avatar
I just replaced the head gaskets so when i put it all back together i installed new plug wires,plugs, rotor,cap. I have a snap-on scan tool and I have no codes and everything is o.k.
Old Jul 21, 2002 | 09:41 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Do a compression test, especially if you used shim head gaskets.
Old Jul 21, 2002 | 09:50 AM
FJK's Avatar
FJK
Some of your mod's can increase HC, so do the following. Reset your timing to 0 deg. Install a 180 or better yet a 195 thermostat.
Retarded timing & higher coolant temps reduce HC emissions. You'll get more bang for the buck by retarding timing.
racereese
Oct 3, 2015 03:46 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
6998poncho
Sep 25, 2015 02:56 PM
