Starting problems
Old Jul 22, 2002 | 01:08 PM
chuck6860's Avatar
Starting problems
ok, here's the problem, key turns and all it does is buzz, no crank, nothing. I had the battery tested and charged and it's fine, changed the ignition switch, put new battery cables on there and had the starter checked and it's "supposed" to be fine. still nothing, however when I try bridging the battery terminal to the motor terminal on the starter, it started cranking,,, problem was it wouldn't stop cranking, it did manage to start but i couldn't get it to stop cranking till i disconnected the battery, and then it was smoking, (the starter). anybody got any ideas as to what it could be now? neutral start switches? wiring? any ideas?
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
