How will a XE268 cam idle in my 305
Old Jul 24, 2002 | 05:15 AM
LarsZ28's Avatar
I have already bought it for my 305, and wanted to know how it will idle? Anyone with this cam in their 305, or 350?
PS here are the specs for those unfamiliar with the cam.
PART # 12-242-2
GRIND NUMBER: CS XE268H-10
ENGINE: CHEV SML BLK 265-400
INTAKE EXHAUST
VALVE ADJUSTMENT HYD HYD
GROSS VALVE LIFT .477 .480
.006 TAPPET LIFT 268 280
VALVE TIMING OPEN CLOSE
006 INT 28 BTDC 60 ABDC
EXH 74 BBDC 26 ATDC
THESE SPECS ARE FOR CAM INSTALLED
AT 106 INTAKE CENTER LINE
INTAKE EXHAUST
DURATION AT .050 224 230
LOBE LIFT .3180 .3200
LOBE SEPARATION 110
Old Jul 24, 2002 | 06:14 AM
ChrisFormula355's Avatar
Car: Junk
Engine: Junk with nitrous
Transmission: Junk with gears
I think in a 305 it would be pretty lumpy. I have that cam in my girlfriends 350, and I had one in my firebirds previous 350, and it idles fairly smooth, with a little rump to it, in a 305 it would probably idle a little bit lumpier.
Chris
Old Jul 24, 2002 | 08:19 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
The XE268 is not good for a 305, way too much lift and duration. Take it back and get an XE256. That is as big as you want to go, even in a well built 305.
Old Jul 24, 2002 | 08:21 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
How will it idle in my 350. I just ordered the cam tonite.
Old Jul 25, 2002 | 01:23 AM
Engine: 305-4v
A lot better because of those 45 extra cubic inches. I don't know if you'll like it, though. An XE262 might give you a more enjoyable driver, but if you want a lumpy idle I suppose the 268 will provide more of that.
Old Jul 25, 2002 | 05:23 AM
LarsZ28's Avatar
This motor -> http://www.angelfire.com/nb/thirdgen/343hp305.html
built by lunati, is a 305 with a larger cam than the XE268.
And has a lower lobe seperation degree.
Anyone else have experience with the idle with the XE268 cam in either a 305 or 350?
Old Jul 25, 2002 | 07:05 AM
boogie's Avatar
Take some good advice from myself and others and send that back. Yea, you will sound cool but you will wish you had it out of there in no time after some city driving. You did not list your mods,induction,gears or intended useage but the XE256 mentioned would be a good all around choice for a 305.
Lonnie
Old Jul 25, 2002 | 07:20 AM
boogie's Avatar
I noticed the lunati engine after i posted. The XE262 would not be a bad choice if you had some 3.42 or 3.73 gears.
Lonnie
Old Jul 25, 2002 | 07:42 AM
LarsZ28's Avatar
Maybe I should have mentioned that I drive the car maybe 2 times a month. It will have ported and polished heads (vortec heads will be on later), just under 9.5:1 compression, 600 Double pumper Holley, through a T5 trans, and 9" with 3.9 gears.
Old Jul 25, 2002 | 08:01 AM
Car: 99 Formula
Axle/Gears: 342
Yeah my IROC is no longer a daily driver, so it won't be driven during the fall/spring semesters this year. It gets driven an avg of 5 miles a week right now I would say. The more lope to it the better, plus that gear drive will sound mean, it's a quiet one, but still.
Old Jul 25, 2002 | 08:04 AM
LarsZ28's Avatar
Hi Mark.. when are you putting the XE268 into your 350?
Would love to hear how it goes! .. keep me informed when its done
Old Jul 25, 2002 | 05:33 PM
Engine: 305-4v
F-Bird'88 has found that gear drives actually DECREASE your hp
His buddy's engine lost somewhere around 40 hp, if I remember correctly
Old Jul 25, 2002 | 05:51 PM
Car: 99 Formula
Axle/Gears: 342
Are you serious, maybe I should ask this on the board? 40hp is a crap load. I'll be putting the cam in early next week, but still need to order the locks/retainers for the springs. Doh.
Old Jul 25, 2002 | 06:39 PM
Beast5spdGTA's Avatar
Car: 2007 Corvette Z06
Engine: LS7
Transmission: 6 speed
I think that cam is a little big for stock heads, but since you have a carb, it may alright. That cam in a 305 makes me think GOOD flowing heads and a single plane.
Anyways in my 305 TPI (siamesed base) stock heads
i have the crane 2032 214/220 ~.5" lift w/ 1.6 RR
Idle sounds good, much better than stock, some loss of power below 1500 rpm, pulls hard and runs fastest shifting as high as i can right now at 5500 rev limited. I drive this car everyday, so it's still completely streetable, however my cam is a lot smaller than what you're talking about.
Old Jul 25, 2002 | 07:22 PM
Marc 85Z28's Avatar
SittingBull:
I'll laugh for days with that one:sillylol:
Mark: I was considering putting in a XE268 a while back, but decided Vortec's weren't worth it and chose the XE274 to match up to a set of AFR 195's. I guy at my job has an 84 Blazer with that XE268 cam, stock heads, Performer RPM intake and headers and it runs strong and sounds mean. Idles nice at 800rpm with just right amount of lope to warn other. No problems with power brakes or HVAC. And don't believe that 40HP loss from a gear drive either Something else wasn't right there.
These cams don't behave like the older grinds so don't say their too big until you have experience with them.
Old Jul 26, 2002 | 05:19 AM
LarsZ28's Avatar
Is that a 350 in your mates Blazer?
Jake_92RS
Jan 28, 2020 10:37 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
camaro71633
Sep 1, 2015 10:24 AM
