Initrial Timing Setting
Old Jul 30, 2002 | 09:32 PM
DTL504's Avatar
Car: 84 Z28 Convertible 2 Seater
Engine: Dart Little-M SBC 400
Transmission: Pro-built Automatics 700R4
Axle/Gears: Strange Engineering 3:73
Where should I position the distributor cab for initial timing to start my car during start up, so that it will crank on the first try. I dont want to be turning the distributor while trying to get the engine to start. Please give me a good reference point. The camshaft and crankshaft is already set to TDC.... 12 o'clock crank, 12 o'clock camshaft...
Old Jul 30, 2002 | 10:21 PM
jfox55's Avatar
I would try around 10. But I wouldn't think you would have any trouble around 12. Give it a try, let us know what happens.
Old Jul 31, 2002 | 08:30 AM
ede's Avatar
ede
if you set the gear dots straight up it's set to fire on #1 so pint the rotor to #1. getting ti to fire without moving the distributor even when everything is right is being a little optomistic i believe.
Old Jul 31, 2002 | 10:26 AM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
point the rotor to #1 like ede says and put a timing light on it, two or three cranks should tell you how far you're off
Old Jul 31, 2002 | 11:48 AM
thunder87's Avatar
just went thru this
Well, your car might be a different set up than mine, I'm unfamiliar with the ignition set ups. Mine is a non HEI set up - no coil under the cap. What I did: Get the engine set on #1TDC. The timing mark has to be aligned with 0 (the largest notch out of the timing tab). Once you have it at #1TDC, hopefully the distributor will drop right in - it should as long as you're on #1TDC and you have the rotor correctlypositioned. The distributor will be able to go in 2 ways: with the rotor on #1 or #6 on the cap. Make sure you're on #1 on the cap by doing a visual. As long as you have the rotor on #1, the firing order correct, the engine on #1TDC and the valves adjusted correctly (not too tight) the engine will start on the first try. Good luck.
Old Jul 31, 2002 | 11:54 AM
ede's Avatar
ede
to use thunders method you need to make sure it's at #1 compression or there's a 50/50 chance it's at #1 fireing, could be at #6. if you have both dots straight up it's at #1. also the distributor maynot drop right in because of the driveshaft to the oil pump. you can position it with a long screwdriver.
specialized
Jun 18, 2022 09:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Andrew6.688
Dec 13, 2015 10:59 AM
