Help!!! IROC running like CRAP
Old Jul 31, 2002 | 11:07 PM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
Car is an 88 IROC 5.0 TPI, 5-Speed. I was driving on the freeway then all of a sudden **poof**, power goes to hell, idle is erratic as hell, engine occasionally dies at idle, idle speed is all over the place, engine starts cutting out, SES light occasionally flashes on, but does not stay on, and engine RPM drops very rapidly when I clutch the thing to shift, whereas it used to drop slowly.
I take the thing to the shop. It's due for it's 30k tuneup and service anyway. They clean the injectors and throttle body, replace plugs, rotor and cap, replace plug wires (car has 120k on it), and tell me the cat has failed (busted/overheated guts) and the o2 sensor may be bad. All that gets replaced.
It still runs like crap, but not quite as bad. Power is still way down, idle is smooth but idle speed varies. New cat smells like it's getting really hot. Engine RPM still drops rapidly when clutched during shifts. And now, for some reason, the driver-side fan runs all the time, even when the engine is cold.
Any ideas? Computer gone south? Old cat debris plugging the muffler? HELP!!!!!!
Old Jul 31, 2002 | 11:58 PM
XxPichulonxX's Avatar
It does sound like your comp took a big s h I t on you, it could also be something in your ign system.
Old Aug 1, 2002 | 10:44 PM
Tremo's Avatar
Yep, it was the computer. New one in and now it's running like a champ.
Old Aug 1, 2002 | 11:35 PM
iroc22's Avatar
Good to hear.
92camaroJoe
Jul 29, 2023 07:57 PM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
kyleb24
Aug 15, 2015 08:24 AM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 11, 2015 03:17 PM
