Turn the key forward and...nothing
Old Aug 1, 2002 | 06:46 PM
IROCracer's Avatar
My cousin has an 88 TA. For a while now, when he turns the key back for accessory, nothing comes on. Wasn't a big deal. Yesterday, he turned the key forward to start it, nothing happened...at all. The stereo and all the accessories work (when forward), but the car doesn't click, turn, sputter, not a damn thing. Whatcha guys think? Ignition switch? Neutral safety switch? We're gonna go look now, I'll be back to check this post in about 30.
Later,
Kelly
Old Aug 1, 2002 | 07:31 PM
ede's Avatar
ede
check for power to the starter ,maybe fuseablr link bad, nutral or clutch safety switch, bad key cylinder
Old Aug 1, 2002 | 07:38 PM
jfox55's Avatar
I would say that sounds like the neutral safety switch.
Old Aug 1, 2002 | 07:48 PM
Hulk0202's Avatar
Ignition cylinder going bad, VATS
Old Aug 1, 2002 | 08:15 PM
BuckeyeROC's Avatar
Car: 2015 Camaro Z/28 & 2013 Super Bee
Engine: LS7 and 392 HEMI
Same thing happened to me several weeks ago, ended up being the switch. I put in an Ignited push button switch w/ a red lense that says "Engine Start". Not only does it work, but check out your friends' faces when you start the car pushing the button It's pretty cool.
Old Aug 1, 2002 | 08:33 PM
IROCracer's Avatar
Well, we went and pulled the column down, felt around, thought about pulling the console to check the neutral safety switch, but decided against it out of pure laziness.
We tried jumping the starter by running a wire from the hot battery post to the solenoid and not a f u c k i n thing happened. Actually, it made a spark, but that's it. I'm guessin the solenoid was bad. We went and picked up a starter for only 30 bucks new. Is this normal? Was the guy at Autozone smoking crack again? I know when I bought my 6-speed starter, it was well over $100, but that's a lot of f u c k i n metal and s h i t for only 30 bucks.
Kelly
Jae992
Aug 27, 2015 09:07 AM
TheExaminer
Aug 19, 2015 10:07 PM
Bryan F
Aug 18, 2015 02:28 PM
tnrednneck
Aug 13, 2015 08:57 AM
Kaweh
Aug 9, 2015 02:54 PM
