starter installation question
Old Aug 1, 2002 | 10:04 PM
AF_ONE's Avatar
I should have asked in the post below--oh well. I am going to replace my starter in my 84 Trans Am L69 tommorrow. I bought a Delco remanufacture. Is tere anything special I need to do to replace it, other than unbolt the old one and bolt in the new one? Any helpful tips or advice would be appreciated.
Old Aug 1, 2002 | 10:06 PM
88GTAinRI's Avatar
From: Ocean State, lil Rhody, the biggest littlest state in the union, Rhode Island
Car: 1988 GTA Black/Gray
Engine: Blown 355
I highly recommend disconnecting the negative terminal from the battery before you do anything.
Old Aug 1, 2002 | 10:37 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
might have to drop the ypipe, which means you might have to cut it.
Old Aug 2, 2002 | 07:18 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Unbolt.
Rebolt.
No magic to it, no need to disturb the Y-pipe if it's stock, especially don't cut anything, just disconnect the battery before you start. You have to turn the starter to some weird angle to get it to come through, nose down with the solenoid toward the rear IIRC; experiment until you get it through. It will go.
Old Aug 2, 2002 | 07:21 AM
AF_ONE's Avatar
Thanks a bunch! The Y pipe and everything is Stock.
Old Aug 2, 2002 | 07:48 AM
AT4 T/A's Avatar
Car: 1989 IROC-Z
Engine: L98 350
Transmission: New 700r4 Done by 11/14/07!
I've got an '84 LG4. When I had to replace mine, that Y-pipe DEFINATELY was a problem. I was able to weasel that thing out of there though, but it did take about 10 minutes. Just be patient. Once you unbolt the starter, you've got to find the right position for the solenoid to be in to have it slide out. It's not that easy, in fact, it's pretty frustrating.
Old Aug 2, 2002 | 07:52 AM
AF_ONE's Avatar
I have the L69, might that make a difference?
Old Aug 2, 2002 | 08:04 AM
AT4 T/A's Avatar
Car: 1989 IROC-Z
Engine: L98 350
I don't think it will make a difference at all that you have the L69. Just remember: that starter is going to probably **** you off, so be expecting it!
Old Aug 2, 2002 | 09:01 AM
Jyrx's Avatar
Car: Firebird
Transmission: th700
One more thig: That thing is heavy, don´t drop it on your foot!
Old Aug 2, 2002 | 09:04 AM
AF_ONE's Avatar
Right!
Old Aug 4, 2002 | 01:13 PM
AF_ONE's Avatar
Piece of cake--I removed the starter today--2 bolts and two wires, it slipped right through th "Y" pipe--no problem at all. It took more time to jack the car up then it did to swap starters--20 minute job.
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
Wesly_66
Aug 26, 2015 09:55 PM
redmaroz
Aug 16, 2015 11:40 PM
milk
Aug 10, 2015 06:26 PM
