do I have to remove the steering wheel to get ignition switch?
Old Aug 3, 2002 | 01:14 AM
Joshua Leslie's Avatar
hey
I think the prob. with my car is the ignition switch.
I have ran a search, but I am a little unclear about this.
everything I have found says the ignition switch is on the top left at the base of the steering colum, however, it does not say if I need to remove the wheel or not.
so do I?
thanx
Old Aug 3, 2002 | 06:06 AM
ede's Avatar
ede
basically it's on the floor (steering column), not under the steering wheel, are you getting it confused with the lock cylinder ,which would be under the steering wheel.
Old Aug 3, 2002 | 02:25 PM
yeah, im talking the ignition switch, not the lock/key tumbler.
so I do not need to remove the steering wheel?
Old Aug 3, 2002 | 03:33 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
no, you do not.
It sits on top of the steering column, about 5 or 6" from the firewall. it's held on by 2 screws, 1/4" IIRC. There's a rod that goes all the way from the lock cyl down to the switch.
Old Aug 3, 2002 | 05:02 PM
thanx man
Old Aug 3, 2002 | 09:38 PM
Zirtbow's Avatar
You have to drop the column to get that bastard out though.. you take that plastic piece out from under the column and then look under it.. there are 2 bolts that hold it up.. loosen those up and don't let the column hit you in the head (it sorta hurts) then disconnect the wires that go into the switch.. and take the 2 screws that hold the switch on.. I couldn't figure out how to get that wire out of that plastic thing on the side.. so I just pulled the old ignition switch down.. screwed off that plastic piece (the one that wires goes totally through) and screwed it onto the new switch.. put everything back together and no more ignition switch problems...
Frozer!!!
Jan 19, 2024 04:55 PM
backtothe80s
Sep 5, 2015 12:39 AM
Bull86
Aug 10, 2015 05:43 PM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
mustangman65_79
Aug 9, 2015 03:00 AM
