blow by
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Blow by means cylinder compression is getting past the rings. You can usually see it by looking in the valve cover through a hole like the PCV. If excess pressure builds up in the crankcase then it can cause a lot of oil leaks plus the engine will be down on power.
The only way to fix blow by is with a rebuild. You need new piston rings. The cylinder walls could be out of round also requiring boring out the engine.
Looks like a good time to consider a 350.
blackz281le
Jan 11, 2016 07:51 AM
