Fuel pump keeps coming on???
Old Aug 6, 2002 | 12:27 AM
SARswmr's Avatar
I've looked in the archieves and found something similar but couldn't tell if my problem was the same.
Today after changing my oil I was flushing the radiator and while opening the drain plug I noticed the fuel pump was coming on, but the key was off and halfway pulled out of the ignition. I pulled the relay by the firewall but it still kept coming on every few minutes and then it shuts off and repeats this until I disconnect the battery. Any help would be appreciated.
Is this possibly an oil pressure sending unit relay? going bad.
Thanks for any help. I just got this IROC yesterday and I'm just trying to work out the bugs since it's benn sitting for a year.
Thanks,
Tim
1988 IROC Convertible
400 small block w/TPI -- she flies
Old Aug 6, 2002 | 04:27 PM
SARswmr's Avatar
Anyone????
Anyone ever have any experience with this??
Need help.
Old Aug 6, 2002 | 06:52 PM
89WS-6's Avatar
You can always make a manual switch for this, just like you can you fan. Thats my suggestion.
Old Aug 10, 2002 | 12:56 AM
CALIROCZ28's Avatar
Car: '98 Z28 LS1
Transmission: 4l60E
Axle/Gears: 373
Re: Fuel pump keeps coming on???
The problem you described is your oil pressure/fuel switch that goes into the side of your block next to the oil filter. Or next to the Distributor towards the rear of the engine. Check the plug by wiggleing it around if the fuel pump comes on then most likely it is the switch itself. $25.00 at most parts stores. $50. at your local Chevy dealer for the same identical switch.
Good Luck!
Old Aug 10, 2002 | 09:29 AM
SARswmr's Avatar
Thanks Cali
I'll check it today....
Old Aug 11, 2002 | 10:34 PM
Vader's Avatar
I'll vote for wiring or the auxilliary oil pressure switch:
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
Jae992
Aug 27, 2015 09:07 AM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
