low air flow
Old Aug 6, 2002 | 05:48 PM
zach's Avatar
low air flow
When I run the air conditioning I get a code for low air flow. It onlf happens when the air is on. It takes about 15-20 mintues for the code to pop up. It happens every time. But only when the air is on. It is an 85 tpi Trans Am. What can I do to correct the problem. The IAC is fine and clean.
Thanks !
Old Aug 6, 2002 | 06:41 PM
89WS-6's Avatar
if you have the air on, and you are at a stop with it in drive, what is it idling at? Try checking your timing, and check to see if your MAF is ok.
Old Aug 7, 2002 | 03:52 PM
zach's Avatar
It idles at about 650-700 rpm. The MAf is fine. I have a computer to check all the sensors and everything is in range. The car runs well even when the light comes on. It just wants more air.
I have a k&n air filter.
eightsixseven
Dec 16, 2024 01:50 PM
chazman
Aug 28, 2018 03:25 PM
Keith5
Aug 27, 2015 04:37 PM
chazman
Aug 22, 2015 02:01 PM
