Car still not making power 2500+ rpm..
Old Aug 4, 2002 | 09:09 PM
BillZ28's Avatar
Car: 84 Z28
I notice in most in 1st gear. I just got a new fuel filter and fuel pump put on the car so I don't think it is a fuel line problem, though the fuel pump did make it a little quicker.
I'm thinking maybe it's something with the carb? The valve seals are bad but I don't know if that'd affect performance would it?
Old Aug 4, 2002 | 09:13 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Your catalytic converter might be getting plugged.
Old Aug 4, 2002 | 09:31 PM
iroc22's Avatar
I had the same problem and it turned out to be a ignition module was bad.
Old Aug 5, 2002 | 12:03 AM
BillZ28's Avatar
Car: 84 Z28
Ok, I'll replace the Ignition module and see what happens.
Old Aug 5, 2002 | 12:05 AM
BillZ28's Avatar
Car: 84 Z28
Every once and a while I'm getting stumbling and misfiring too, so it probably is an ignition problem.
Any recommendations for a brand of ignition module?
Old Aug 6, 2002 | 08:57 AM
felo72's Avatar
If it's the module, the car probably wouldn't start when the car was hot. Do you have that problem? If not, you might have the same problem I have. At idle, the car runs ok, put it in drive and take off, and it runs pretty rough and backfires through the intake, right? If the seals are bad, and the ignition module is not your problem, I'd check the cam. Pull a valve cover off and check all of the springs. It's a simple test, just make sure they are going up and down. Let me know how you make out.
Old Aug 6, 2002 | 12:54 PM
iroc22's Avatar
My car would start anytime with a bad module.
Old Aug 6, 2002 | 04:58 PM
BillZ28's Avatar
Car: 84 Z28
It starts when hot, just not right away.
Old Aug 7, 2002 | 08:57 AM
felo72's Avatar
Not to start a fight, but if your car would start when hot with a bad module, how did you know it was bad?
Old Aug 7, 2002 | 11:55 AM
iroc22's Avatar
Because I got a SES code (cant remember which one) that was module/ESC. Replaced the module and it never threw any more codes.
Old Aug 7, 2002 | 12:02 PM
felo72's Avatar
Duh, sorry, I forgot about the SES light coming on.
Old Aug 7, 2002 | 12:20 PM
BillZ28's Avatar
Car: 84 Z28
I wish mine threw a code so I knew what the problem was.
Old Aug 7, 2002 | 01:12 PM
gruveb's Avatar
Car: 1989 IROC-1
I purchased several of the generic brands of ignition modules sold by the chain parts stores and none lasted very long. I purchased an Accel and it hasn't failed me at all.
Let me check that....before I had some engine mods the generic modules were fine, but after the mods I made, the generic mods would just fry out on me in no time at all. But the Accel has worked perfectly, no problems.
Old Aug 7, 2002 | 04:51 PM
iroc22's Avatar
The Accel module is just a Corvette module pretty much. If you get a MSD one, it's a step above.
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
jaridjohn
Jul 8, 2024 03:49 PM
jhawkeye
May 25, 2022 06:33 PM
midge54
Dec 27, 2019 04:14 PM
Reborn756
Sep 4, 2015 03:42 AM
