is there such a thing as a.......
Old Aug 6, 2002 | 09:59 PM
firechicken_3's Avatar
Car: 1984 Firebird
Engine: 350 Terminator EFI
Axle/Gears: 4.10
tall deck 350, block?
a friend was looking for a motor and someone wanted what seems like alot of money for a well used stock short block, while claiming that it is a TALL deck.
i know of tall deck big blocks, thats how we get the 502 unless i'm mistaken
so tell me folks, is there such a thing?
Old Aug 6, 2002 | 10:59 PM
ede's Avatar
ede
the 502 is a 454 with a longer stroke crank and larger bore. the 427 and 366 (i think) are the only chevys that came in tall deck and they're both big blocks
Old Aug 6, 2002 | 11:10 PM
Car: 1984 Firebird
Axle/Gears: 4.10
a big block that is only 366 cu. in.
thats crazy, never heard of it before,is that like the big block version of the 305?
Old Aug 6, 2002 | 11:37 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Alum Bow Ties: 9.525" deck height.
Bow Tie Rocket Blocks: 9.325" deck height.
Old Aug 6, 2002 | 11:56 PM
ede's Avatar
ede
guess i never considered the aftermarket or gmpp blocks. there would be several but still none factory instaleld in a thirdgen. if it is a preformance block it'd have some markings on it that would make it stand out and a few other things, like blind head bolt holes
Old Aug 7, 2002 | 12:01 AM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
EDE - Did you mean the 396?? I know that's a big block.
Old Aug 7, 2002 | 12:10 AM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Oops, firechicken_3 did say "stock". Nevermind..
Old Aug 7, 2002 | 12:14 AM
NTChrist's Avatar
No, there was a 366 BBC.
It came stock in some trucks.
As with most truck BBC's, it was a tall deck.
Old Aug 7, 2002 | 12:26 AM
87'IROC5.0's Avatar
Yep, a commercial truck engine.
Old Aug 7, 2002 | 02:06 PM
NTChrist's Avatar
409 & 348
Aren't the 409 and 348 chevy's tall deck blocks?
Maybe your friend has confused 348 with 350.
Old Aug 7, 2002 | 02:23 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
No. They are rather tall, but they're not "tall deck" blocks, since there's no "short deck" version of the same motor. Good guess trying to decipher the "mind" of an uninformed person though.
The 366 and 427 are the only Chevy motors found in production vehicles that would be considered "tall blocks". The passenger car motors, which are 396, 402, 427 and 454, are all "short deck".
F*rd uses this method throughout their product lines; for instance, the 302 is a "short deck", the 351W is a "tall deck". The older FE blocks seems like had several deck heights.
Olds & Pontiac have also done this. For instance, a Pontiac 389, 326, 400, 350, or 455 is a "tall deck" (although nobody calls it that, those are just the standard Pontiac motor), while the 301 is a "short deck". In Olds, the 400 & 455 are "tall deck", but the 350 and 403 are "short deck". You see all kinds of arguments allt he time about Pontiacs being either a "big block" or a "small block", but they're not, they're either tall or short. The bore spacing is the same on all their blocks, which is one of the 2 or 3 most basic measurements of a production engine block (along with deck height...)
morrow
Jan 13, 2024 12:29 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
TheExaminer
Aug 19, 2015 10:07 PM
Bob88GTA
Aug 18, 2015 03:31 PM
