Code 15....
Old Aug 7, 2002 | 03:58 PM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
Code 15....
Well I got my car running, looks like it was my coil...bad news I am getting a code 15 now. 15 Coolant sensor - low temperature fault
So what does that mean? Do I need to change out my Coolant temp sensor now on my manifold? *** dang this car is full of surprises. After i burned all the soot off the plugs i checked my fuel pressure, i am running about 15psi for TBI vehicle which stock is 9-10psi. I uped it though but i don't think thats to bad. I wouldn't want to go any furthur. Anyways how much to CTS cost usually?
Old Aug 7, 2002 | 05:46 PM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
Yup, it get rid of my code 15 and now all I have to do is lean my car out (plugs were black) and everything should be back to normal.
Old Aug 7, 2002 | 07:04 PM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
Well i got it from 16psi to 14 psi, but it seems no matter how many times i turn the damn adjustable fuel pressure regulator it only decreases a little bit. Any thoughts on that? Anyways, we will see what this does.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
