head question
Old Aug 8, 2002 | 12:40 AM
PIMPINPHIL's Avatar
head question
hi,
i was just wondering what all heads would work with my 77 350,i have 10.1 pistons,i mean like would l98 heads work?or lt1 heads work?and if either,what would i need to convert to carb,thanks.
Old Aug 8, 2002 | 01:52 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
The late Lt-1/ LT-4 heads are of a reverse cooling design and do not work on other conventional small blocks.
Any of the other heads will work with flat top pistons.
If you have domed pistons then piston dome to head clearance may need addressing on some heads.
The L-98 heads have good performance potential if you're
willing to put the work into them. (porting valves etc)
"081,083, 217 are the castings to look for.
The "swirl port" type heads should be avoided for a performance motor.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
NinjaNife
Aug 23, 2015 11:49 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
