weirdest thing happened.....
Old Aug 8, 2002 | 01:56 AM
Jer82Z28's Avatar
Car: 1987 IROC
Engine: Vortec 350 TPI
Transmission: 7004r
I goto start my car this morning, turn the key and no power at all to the starter
power to everything else, and plenty of power, put the charger on and the battery was great.
so I take a screwdriver and touch posts on the starter. it turns over.. but it freewheels? the starter spun but didn't turn the engine
didn't think that was possible so I figured the starter is toast.
I decide to try to start it one more time
hit the key and it fires up
HUH?
later that day it does the exact same thing, nothing worked, I touched posts on the starter again and the key works again.
the connections on the starter are solid, the cables brand new, ignition switch brand new. It acted like i had it in gear and tryed to start it. nothing happens.
I tried to start in all gears, nothing happens until i touch posts.
Old Aug 8, 2002 | 02:03 AM
rezinn's Avatar
If it freewheels then the bendix isn't making contact with the flywheel, so either the starter is needs to be rebuilt/replaced or the flywheel is missing some teeth. Since it has started, I figure it's the former case.
Old Aug 8, 2002 | 02:06 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
The starter solenoid is going bad. Replace it.
Old Aug 8, 2002 | 07:05 AM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
I agree with F-BIRD'88, replace the solenoid.
morrow
Jan 13, 2024 12:29 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
TheExaminer
Aug 19, 2015 10:07 PM
Bob88GTA
Aug 18, 2015 03:31 PM
