which pistons?
Old Aug 8, 2002 | 02:41 AM
titeride85's Avatar
which pistons?
I am fixin' to build a 406. I will be using 5.7" rods. So I need new pistons anyway, and i want something rated for higher hp. But I want to know, which pistons are better for the price.
Keith Black or Speed Pro?
Or if you know of other affordable pistons...
I would like to buy Ross but cant shell out that much more money. So what are your thoughts?
Old Aug 8, 2002 | 05:56 AM
ede's Avatar
ede
no power adder i'd run the hypers. you'll have to file the rings.
Old Aug 8, 2002 | 03:49 PM
felo72's Avatar
Which Speed Pro's? The cast or hypereutectic's? It all depends on what kind of performance you want out of the engine. If you don't plan on running nitrous or a blower, either will do, if you do, go with the TRW forged. Those are owned by Federal Mogul, the same company that owns Speed Pro, Fel-Pro, Sealed Power, and Sterling. If you don't plan on running a blower or nitrous but plan on running around 10:1 compression, use the hypereutectics (Keith Black). If you don't run too much compression, and don't plan on racing, run the Speed Pro's cast pistons, they're cheaper and still do the job.
NZKnight
Oct 15, 2015 02:47 PM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
hartsmike
Oct 2, 2015 07:11 AM
Dragonsys
Sep 25, 2015 03:51 PM
