fuel injectors?
Old Aug 8, 2002 | 05:40 PM
slp_firehawk's Avatar
fuel injectors?
is changing fuel injectors on an 89 trans am gta 350 a big job, i'm in a hurry right now have to go tow the car down here, but i'll write more info about it soon...
Old Aug 9, 2002 | 09:31 AM
Vader's Avatar
A good eight-hour job - if you have all the materials on hand and don't plan to do the other things you probably should do once the plenum is off.
Old Aug 9, 2002 | 06:26 PM
wondering what psi stock fuel injectors are for an 89 gta 350tpi, also any performance gains by putting bigger injectors into a pretty stock engine, no major things....just computer chip, cold air, and catback exhaust?? thanks
Old Aug 11, 2002 | 10:05 AM
Vader's Avatar
The fuel rail pressure for an L98 TPI should be 37 PSIG, +/- 3 PSIG. That is at idle with the regulator vacuum line connected. Disconnecting the vacuum line should increase the pressure to at least 44 PSIG.
If you were asking about flow (fuel output) of the injectors, an L98 should have 22 lb/hr injectors. A 305 would have 19 lb/hr injectors. Increasing the flow rate of the injectors on an otherwise stock engine will probably have negative results. It would be more cost effective and probably more effective overall to convert the pressure regulator to an adjustable type so the maximum fuel pressure can be tailored to the modifications you might make. When modificaions become more serious, you may want to considered the ECM PROM for reprogramming to match your combination. Examples of this would be a more aggressive cam profile, significant intake tract modifications (not just plenum porting) and head/valve work.
Old Aug 11, 2002 | 11:15 AM
Morley's Avatar
Takes 3-4 hours to change the injectors on a TPI, thats taking my time and making sure everything is righe before reassembly.
bryan623
Mar 22, 2021 06:43 PM
New2Chevy
Oct 4, 2015 11:27 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
