edelbrock airgap vs. weiand stealth
Old Aug 10, 2002 | 09:11 PM
uidzer0_z28's Avatar
hey guys,,
I just swapped out my edelbrock airgap intake for a weiand stealth and it seems to be worse not better. Should it be this way? I thought that I would see some low end gains from the stealth and gain the hood clearance. I got it installed and put everything back to how it was and found that it is worse... So i figured some things needed to be tweaked a little. I reset the idle mixture screws on my carb for maximum idle and got the timing set again. Still seems to be really sluggish on the low end. When i get moving (finally) it seems to be alright like when I am going 60+ mph. On top of all that my exhaust is much quieter.
Does all this seem right?
thanks,
Ben
Old Aug 11, 2002 | 07:10 AM
ede's Avatar
ede
might want to play with the timing, i like the weiand intakes, have used several on differant SBCs i've done.
Old Aug 11, 2002 | 09:53 AM
hrm,
I can't figure it out. I have had the timing all over the place. It dosn't seem to get better. How many degrees to you recommend I advance it?
-Ben
Old Aug 11, 2002 | 10:04 AM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
Whats the part #s on both the intake manifolds?
Old Aug 11, 2002 | 12:37 PM
stealth = summit part # WND-8016
air gap = summit part # EDL-2601
-Ben
Old Aug 11, 2002 | 03:25 PM
ede's Avatar
ede
i'd shoot for 34 to 38 total
Old Aug 11, 2002 | 04:45 PM
damnit, i knew I should have got the dial timing light instead of this damned cheap one, at the time i thought this one was better. /me kicks self in head
-ben
Pac J
May 17, 2020 10:44 AM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
efiguy
Sep 27, 2015 01:30 PM
JSDaddy189
Sep 26, 2015 03:50 PM
Night rider327
Sep 25, 2015 04:47 AM
