Getting TDC on Comp Stroke (heads off)
Old Aug 11, 2002 | 04:03 AM
LarsZ28's Avatar
I have the heads off, and obviously distributor is out. How do I make sure that Piston #1 is at TDC on the compression stroke?? Is it when the #1 lifters are down, (not on cam lobes)??
Just getting ready for new cam to go in. Thanks
Old Aug 11, 2002 | 04:56 AM
ronterry's Avatar
Car: '94 Corvette
...also I think one of the #6's will be up...Then you know your at #1 TDC, & not #6 TDC...
If you have the chain cover off, the cam & crank gears will have both dots straight up @ 12 O'Clock...
Ron
Old Aug 11, 2002 | 06:54 AM
ede's Avatar
ede
both valves closed, dampner mark lined up on timing tab, piston at top of stroke, also 6 will be up. with the heads off you won't know if it's fireing on 1 or 6. if you have the timing cover off then make sure both dots are straight up and it'll fire on 1.
Old Aug 11, 2002 | 01:03 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If the cam isn't in the engine, then there's no difference yet between the 2 instances of TDC, because the cam is the thing that does that...
Just put the motor at #1 & #6 TDC, slide the cam in, line up the dots (cam dot and crank dot right next to each other), and you'll most likely be at #6 firing. Turn the crank one full revolution, you will be back at #1 & #6 TDC again, the cam will go ½ revolution, the dots will both be straight up, and the motor will then be at #1 firing.
gixxer92
Sep 1, 2015 04:32 PM
355tpipickup
Alternative Port EFI Intakes
Aug 29, 2015 10:47 PM
mz92274
Aug 25, 2015 08:47 AM
LT1Formula
Aug 20, 2015 09:36 PM
