Cracked bolt hole :(
Old Aug 12, 2002 | 04:55 PM
AlexJH's Avatar
Engine: 5.7L V8
I bought a 400 short block a while back and I've been taking it apart and cleaning it up.
In that process I discovered that one of the bolt holes for the a head bolt has a crack running to a coolant passage right beside it.
I thought I'd get opinions on the board to see if I should worry about it, before I drag it to a machine shop.
Old Aug 12, 2002 | 05:22 PM
ede's Avatar
ede
yeah either you can weld it and machine it or trash the block
Old Aug 13, 2002 | 11:00 AM
AlexJH's Avatar
Engine: 5.7L V8
Hmm... how pricey will that be?
Old Aug 13, 2002 | 11:16 AM
83 MidniteZ's Avatar
I would find another block. The amount you are going to spend to get that fixed will be close to finding another bare block, and I just woulnd't feel comfortable building something that i know potentially could have a problem and may end up being torn down again later. Just my $ .02
Old Aug 13, 2002 | 11:28 AM
Vader's Avatar
You might want to "drag it off to a machine shop" anyway, if for nothing else than to Magnaflux or ultrasound the case to see if there are any other hidden cracks or stress points. If it is a single crack with no other problems, weld, stress relieve, and machine the hole. If there are more problems....
Old Aug 13, 2002 | 11:58 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Pretty comon problem, usually results from over-torquing the head bolts and then overheating the motor.
Like ede said, it's repairable, that's not a big deal as repairs go and not very expensive. Probably a whole lot less than a new block. Sometimes they fix it by drilling the deck and putting in a pipe plug, then drilling and tapping that.
evilstuie
Jan 9, 2020 08:29 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
LittleFranks
Aug 20, 2015 03:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
