WHich wire is the #1 spark plug wire
Old Aug 12, 2002 | 10:00 PM
jfox55's Avatar
The #1 spark plug wire is the one on the drivers side all the way up front right. Just checking, According to my timing light off of this wire my car WAS at about 19degrees before tdc. I dropped it down to about 12btdc. Just wanted to make sure you check your timing off of the drivers side wire all the way in the front.
Old Aug 12, 2002 | 10:57 PM
Craig84Z's Avatar
Car: 1984 Camaro Z28
Engine: Blueprint 383
Correct.
Old Aug 12, 2002 | 11:10 PM
ronterry's Avatar
Car: '94 Corvette
Jason, You'll want to clamp the wire as close to the spark plug as you can get, but not on the boot, and not touching the exhaust.
Ron
Old Aug 12, 2002 | 11:25 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
#1 plug wire can be anywhere on the distributor. It all depends on how the distributor was dropped into the engine. With #1 cylinder at TDC you can pull the distributor, turn the oil pump drive with a screwdriver and drop the distributor back in with the rotor pointed at whatever plug wire you want. That plug wire could now be #1 and the rest of the wires would need to be rotated around to match.
#1 cylinder is always the one at the front of the engine. On chev the driver side is more forward than the passenger side.
Old Aug 13, 2002 | 03:46 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Oh I am so happy to hear that said! I had such an arguement over that a while ago (January of 2001) : https://www.thirdgen.org/techbb2/sho...threadid=60772 Maybe this old message will help explain things... keep in mind it's for a 2.8 V6, which has a different #1 cylinder than a V8, but same principles apply...
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
g.l.mos
Aug 22, 2015 12:02 AM
Bryan F
Aug 18, 2015 02:28 PM
