wiring a tach
Old Aug 14, 2002 | 04:19 AM
mattRS's Avatar
wiring a tach
red=power
black=ground
green=?
white=?
which goes to tach, and which is the power for the light?
Old Aug 14, 2002 | 09:23 AM
ATOMonkey's Avatar
I think that green is power for the light and white is the tach signal. Could be wrong though. Why don't you ask the manufacturer.
Old Aug 14, 2002 | 09:32 AM
firechicken_3's Avatar
Car: 1984 Firebird
Engine: 350 Terminator EFI
Axle/Gears: 4.10
[QUOTE]Originally posted by ATOMonkey
I think that green is power for the light and white is the tach signal. Could be wrong though. Why don't you ask the manufacturer. [/QUOTE
actually mine uses green for signal , and white to power the light, but then again, every manufacturer is a little different, ]
Old Aug 14, 2002 | 12:46 PM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
Axle/Gears: 7.5 with 3.42 gears
mine also uses green for tach signal, and white for light.
Old Aug 14, 2002 | 02:43 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Open up the back and see which one goes to the light bulb.
Mine's white.
Old Aug 14, 2002 | 04:09 PM
Marshall89ws6's Avatar
red should go to the inj fuse....... white to the gauges fuse for light...... green always goes to the dist or ignition box..... i run mine to my msd box its got its own tach drive.... the black is a ground
Old Aug 15, 2002 | 09:21 AM
MIG-29's Avatar
Car: 1987 Camaro
Engine: 1986 350
Transmission: T-5 NWC
mine also uses GREEN for the SIGNAL
Fernando.
eightsixseven
Dec 16, 2024 01:50 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
Armored91Camaro
Aug 25, 2015 12:01 PM
stalkier
Aug 7, 2015 04:49 AM
