Just replaced a belt, new when I mash the accelerator it will sqeal!!
Old Aug 14, 2002 | 09:24 PM
jfox55's Avatar
Like I said, I just replaced one of my belts on my car. It is the one on the left that turns the altenator and stuff. Now, the belt is quiet all the time except if I just mash it to the floor up to like 4500 or so, it will let out a sqeal. Does this mean my belt is too tight, or too loose?? I thought the tension felt pretty good, but what is your opinion.
Old Aug 14, 2002 | 09:31 PM
rezinn's Avatar
Push the belt down, how much play does it have? If you didn't readjust it after you put it on, it's too loose. After installing a new belt it will loosen, so you have to tighten it.
Old Aug 14, 2002 | 10:12 PM
IROCracer's Avatar
I bet it's too tight.
Old Aug 14, 2002 | 10:52 PM
jfox55's Avatar
doesn't have too much play, but I did notice it right after I put the belt on. Havn't put but maybe 75 mile on the car since I put it on. It feels about the same as the other belt on the car, maybe just a little tighter, but still has some play in it. It felt like plenty to me, I guess tomorrow I will try to loosen it a little. If that doesn't work, then I guess I will tighten it some. Wanted to get a gatorback belt for it, but they didn't have any in stock in my size, so I got the other brand. They did have the same warranty, so i was hoping it wouldn't make any differnce.
Attached Thumbnails Just replaced a belt, new when I mash the accelerator it will sqeal!!-engine-shot-2.jpg
Old Aug 15, 2002 | 02:55 PM
Hung Start67's Avatar
belt
Just do what the boys at the chevy dealership do and that is spray a touch of wd-40 on the belt..will keep it quiet for a touch..check your pullies for rust..that will cause a squeal..set the tension right and if that dont work go get another belt...if all fails there is always budweiser..lol
Old Aug 21, 2002 | 07:24 PM
jfox55's Avatar
Know it's been a little while since I posted this, but the belt was too loose. Loosened it up some and it sqeeled alot, so I tightend it down and it quit. Still think I should have got a gatorback belt though. I still might go back and get one.
1992 Trans Am
May 10, 2023 07:19 PM
BewleyBizzIROC
Sep 7, 2015 08:05 PM
db057
Aug 22, 2015 08:17 PM
wayshegoes
Aug 17, 2015 12:00 PM
scottmoyer
Interior Parts Wanted
Aug 9, 2015 10:18 PM
