Smoking manifold...HELP!!
Old Aug 16, 2002 | 06:50 PM
Matty377's Avatar
Car: '86 Camaro
Engine: LG4
I have smoke coming from the back of my passenger side exhaust manifold.
At first, I thought it was a valve cover gasket leak, so I replaced that, and started the car up.
Still blowing white smoke from the back manifold bolt area...
The smoke smells real bad too, but not like oil. Any suggestions?? Manifold Leak?
Old Aug 17, 2002 | 03:23 PM
ede's Avatar
ede
just about have to be an oil leak, or if you fixed the leak what's left of the oil burning off
Old Aug 17, 2002 | 03:39 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
sounds like your leaking coolant out the back of the manifold from the rear cross-over passage. Old burning coolant smells like crap. Tear it down and clean allt he gasket surfaces and replace the gaslets. That should fix it.
Old Aug 19, 2002 | 01:58 AM
sancho's Avatar
Car: '89 Chevrolet Camaro IROC-Z
Transmission: TH-700R4
Axle/Gears: B&W 2.77 Posi
I don't know enough offhand about which smoke smells like what or what color means what, but when I had a similar problem, it was because the O-ring on the distributor was broken, making oil leak from the distributor hole onto the intake manifold. Might want to check that just to be sure...
Old Aug 19, 2002 | 07:21 AM
WarlocV's Avatar
oil burns blue smoke. coolant burns white smoke. check the afore mentioned coolant problem. thats probably your best bet.
Old Aug 21, 2002 | 07:44 AM
Matty377's Avatar
Car: '86 Camaro
Engine: LG4
Fixed, turns out it was a cracked heater hose dripping onto the intake manifold, around the back of the head, and onto the exhaust manifold. Thanks for your help.
FormulasOnly
Jul 23, 2018 08:47 AM
86White_T/A305
Mar 6, 2016 01:48 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
KCG
Sep 23, 2015 09:05 AM
Accerrito22
Sep 5, 2015 09:34 PM
