washer pump... where is it?
Well, my 87 Formula doesn't have the washer pump hooked up. In fact, I don't know where the stupid thing is! The line from the res. is disconnected, and I can't seem to trace the lines from the wipers...
Can anyone help?
Can anyone help?
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
my washer pump was right on the wiper motor ('84 Trans Am),at the firewall,it was a $10 new part and hook-up is self explanatory,any small rubber hose should do,maybee a "T" connector somewhere,wires to the resevior could be for a level sensor,more than two wires would indicate that a motor is in there too,infact,you should see the motor in there,it's not hiding from you,just open the hood and look!
the pump is built into the wiper motor, if you look at the bottom of the wiper motor there should be two nipples sticking out from the pump, one of them should be leading to the firewall and go to the spray heads the other is the suction from the tank.
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Originally posted by irocbarry
how offen do these burn out
Bohemian
Aug 15, 2017 05:11 PM
Saxondale
Exterior Parts Wanted
Sep 16, 2015 06:32 AM
Saxondale
Sep 7, 2015 06:11 PM
Saxondale
Exterior Parts for Sale
Sep 7, 2015 11:40 AM
