Anybody here know how much a TPS(throttle position sensor) sensor cost¿
Old Aug 19, 2002 | 07:18 AM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
Here is a short story. Well This happens more when its hot outside. I can drive about 5-30 before this error comes up. Its error code 21 or 22. When the check engine light comes on it changes the air-fuel mixture and the car runs like ****. If I clear the error code it runs like it should again. What I have found so far on the web is that this is caused by either high signal voltage from the TPS or low signal voltage. I dont know if anyone else's car does this but sometimes when I have the blinker on the volts move up and down. That should happen on a amp not a blinker or am I wrong?
Old Aug 19, 2002 | 07:46 AM
ede's Avatar
ede
look in the yellow pages under auto parts new and start calling stores in your area. prices vary a lot from place to place. i can usually save 30% at autozone by drive to a store 30 miles from here.
Old Aug 19, 2002 | 02:04 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
www.autozone.com
Old Aug 20, 2002 | 02:04 PM
Originally posted by Ukraine Train
www.autozone.com
I know....I know.... I should of looked. Hey thanx I can use that for some motivation to get it replaced. But check this out! The usage of this part # is higher than any other TPS for another car. 67% frecking percent! Here is the link for the 30 dollar POS.
GM=to design small parts that fail so that the consumer can spend more money on us.
http://www1.autozone.com/servlet/UiB...IRD&PageSync=2
Old Aug 20, 2002 | 02:16 PM
flyway190's Avatar
Check O'reilly too.
www.oreillyauto.com
Old Aug 21, 2002 | 12:59 AM
jizzyz28's Avatar
I WORK AT ADVANCE AUTO
MAN THERE LIKE $20 TO $25, GET ONE FOR AN 88 IROC B/C THEY ARE ADJUSTABLE AND IF YOU MESS WITH A PRE SET ONE YOU SCREW IT UP. IT SHOULD BE SET FROM .35 TO .95 VOLTS. IF YOU HAVE A COMP IT IS EASY BUT IF YOU HAVE TO USE A VOLTMETER IT CAN BE A LITTLE HARDER BUT IT IS AN EASY JOB.
Old Aug 21, 2002 | 10:39 AM
Well I replaced the TPS krapper and I havent got the error code yet but we'll see.
someone972
Aug 30, 2015 12:52 AM
mdtoren
Aug 23, 2015 12:52 PM
perZ
Aug 21, 2015 05:51 PM
mdtoren
Aug 16, 2015 05:45 PM
