84 Z28 5 stars leak air..
Old Aug 20, 2002 | 05:03 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
is there a common known problem that i dont know about with the 84 Z28 5 star 15" mags leaking air ? every couple weeks the pressure is donw to 15 or 20 psi, they all seem to leak at about the same rate, but mostly up front however..
i may just sell or junk the wheels and put on some steel wheels if there is no way to prevent this.
thanks for anything,
Old Aug 20, 2002 | 07:31 PM
ede's Avatar
ede
have you soaped the tires to find the leak? i use windex, it's cheap and there's always some around. if the bead is leaking you can break them down and clean the bead, maybe use a sealer on it. replace the valve cores or the whole stem if they leak.
Old Aug 20, 2002 | 08:59 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
whats wierd is that i just had the tires put on the front cuz of the same problem, but these are better tires anyways, so i dunno,,
everyone says it happens just cuz of being aluminum wheels.,
thanks
Old Aug 20, 2002 | 11:02 PM
PimpRod92RS's Avatar
Car: 1992 Chevrolet Camaro RS; 1986 Oldsmobile Cutlass Ciera Brougham
Engine: LH0 3.1 Liter V6; YBN 2.8 Liter V6
Transmission: TH-700-R4; TH-440
If you already had new tires put on and it still does it, its probably the valve stem. My rims do that and I know it comes from the valve stem because they bubble when i wash the car. Spray water at the valve stem and if you hear a hissing noise of some sort it could just be the valve stem.
Old Aug 21, 2002 | 01:28 AM
Morley's Avatar
Most places put in new valve stems when you get new tires put on. If you can't spot the leak you may want to have a tire shop remove one of them from the rim and clean it up good. You may have corrosion on the bead seating area, that happens a lot in areas where they salt the roads in the winter, or if you live very near the ocean.
Lanz06
Mar 13, 2019 06:07 PM
Jlanz55
Sep 8, 2015 11:28 PM
TheExaminer
Sep 7, 2015 08:34 AM
rjcme
Sep 5, 2015 01:23 PM
tgp1990
Sep 4, 2015 06:24 AM
