10:1 compression w/58cc pistons for under $200?
Old Aug 21, 2002 | 05:14 PM
GilmourD's Avatar
I'm looking for a good set of pistons that will give me not much more thant 10:1 compression with a 58cc head. I'd like them to be under $200. I could get the Silv-O-Lite H3437 for around $150. Any of you guys think those are any good? And those should work with my stock rods, right? It's an 88 350 truck motor that these would be going into.
Old Aug 21, 2002 | 07:08 PM
GilmourD's Avatar
Old Aug 21, 2002 | 08:33 PM
boogie's Avatar
Speed pro H345NP pistons will give you 9.9:1 with a 4.030 bore, 58cc heads and a .038 thick gasket. they cost $16.00 ea.
Old Aug 22, 2002 | 02:23 PM
GilmourD's Avatar
I tried looking up info on the website, but I couldn't find a catalog on there... Where can I get stats on all their pistons?
Old Aug 22, 2002 | 02:28 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Look em up at Summit... they are listed in the Sterling line (yet another brand name of Sealed Power)
Old Sep 3, 2002 | 06:33 PM
GilmourD's Avatar
OK, I ordered those pistons... Problem is, I hear conflicting answers... Do I have to file the rings that I get or do I just use the rings with the supplied gap? I've heard to file them .040" more, my father is telling me that Summit should have the rings meant for the pistons (but they're all crazy chrome moly ones for $120+). So... What should I do?
Old Sep 3, 2002 | 08:25 PM
boogie's Avatar
The H345NP piston allows you to run the standard end gap unlike the KB pistons. It would be a good idea to square up a ring in the bore and see what you got. Get a set of sealed power E251x cast rings or E251K moly rings for your bore size and you should be ok.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
LT1Formula
Oct 8, 2015 08:34 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
skinny z
Oct 5, 2015 06:23 PM
ironbmt
Sep 27, 2015 06:00 AM
