Steering Column
Old Aug 22, 2002 | 07:02 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
Steering Column
Guys I think I may have to replace my steering colum. Something is broke letting the wheel shake in my hand. It is in the end with the steering wheel. The tilt is solid Could the turn signal switch cause this. Any ideas on where it may be broke before I replace the entire thing?
Brian Felts
Old Aug 22, 2002 | 08:07 PM
ede's Avatar
ede
it's not the TS, it's already broke take it apart and see what you get into. other than the bearings and the tilt joint i don't think there's much else in there to let them move.
Old Aug 23, 2002 | 06:05 AM
gmanuel's Avatar
I just had to replace the bearings. They come in a kit from your GM dealer. About $45 cdn.
Old Oct 20, 2007 | 10:02 AM
cowboybuck's Avatar
Re: Steering Column
Ive been searching through the threads to see if I can find my problem and this seems to be the closest. Just in case, here is whats happening: I have a tilt wheele, and it seems like something is lose where the tilt connects to the column. Ive driven the car around like this with no problems, but the wheele moves around all over the place: not just up and down but left and right as well. I could use some help with what might cause it and even better yet, how to take it apart to fix it.
Old Oct 20, 2007 | 10:23 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: Steering Column
https://www.thirdgen.org/forums/tech...ck#post3451256
Loose tilt. See link for fix.
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
Night rider327
Sep 25, 2015 04:19 AM
