swapping in used fuel sender/pump, what parts to replace?
Old Aug 26, 2002 | 08:48 AM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
i just acquired a 91 Z28 parts car and i will be using its TPI fuel pump in my efi swap. what parts, if any, should i replace on the sending unit/pump before i put it in my car? i currently have an intank lg4 pump, will the wiring for it be sufficient for a tpi pump or should i run heavier gage wire?
Old Aug 26, 2002 | 06:27 PM
snakeskinner's Avatar
if you're planning to be modified, put a better pump in there. The wiring will be fine.
Old Aug 26, 2002 | 08:01 PM
Car: '87 Camaro LT
Engine: 355 L98
i hear a stock pump is good for 400hp, i'm gonna be at 370 max. also, i'm on a budget and this is free. if worse comes to worse i'll swap it again later if i put more power on, i dont mind the work all that much. so do i need to replace anything?
Old Aug 27, 2002 | 07:11 AM
not sure where you found that number but I was always told it would only support about 300-350. I know my 350 t/a responded well just from going to a 44gph pump and I was only running 13.9's with well under 400hp.
Old Aug 27, 2002 | 10:55 AM
Car: '87 Camaro LT
Engine: 355 L98
Originally posted by bjankuski
A stock fuel pump is good for approximately 400 HP.
https://www.thirdgen.org/techbb2/sho...hreadid=127561
maybe i should just get a walbro
Frozer!!!
Jan 19, 2024 04:55 PM
NBrehm
Aug 25, 2015 11:49 PM
justin57
Aug 20, 2015 07:05 PM
Fronzizzle
Aug 9, 2015 01:15 PM
1nastygta
Aug 8, 2015 07:38 PM
